Grouping Points
   1402   0   1
Hi everyone!
I have a surface and I have refined its topology using a clothRefine. Because I will need to use the wireframe structure and not the surface, I'm trying to brake the repetitiveness of the triangulation by selecting the points generated by the clothRefine, collect them in different group SOP and reconnect them using an add SOP by group.
Is it possible to select/sort the points generated by the clothRefine in order to keep the new connections from the add SOP shorter and more localized?
Would it also be possible for each and every group to have the perimetrical points always selected?
I have created a simple scene to give you a reference of what I'm talking about.
Any suggestion would be great.
SimpleScene.hipnc (358.3 KB)
