changing inlinecpp ldflags
   1459   0   1
Hi, there. Is there any way to change the ldflags when using the inlinecpp python module? Our libraries are not in the default location so inlinecpp doesn't work directly. I can manually link the compiled object files generated by inlinecpp using hcustom with -L and the resulting library will work correctly inside houdini, but it would be nice if I didn't have to manually link it. Thanks!
Peter.
