HDK: Building utility library
   1486   0   0
Using the $HFS/toolkit/makefile* , one can build DSO and Application.
I am doing some refactoring and need to move a growing code base (which uses/references Houdini headers) which are common/reusable into a separate library/header.
Should I leverage the DSO build facility or should I just build using a standard makefile (with e.g. GCC) as either static/dynamic and as such reference the required header files via $HFS/toolkit/include?
Regards
Nicholas Yue
