hi,
I created a Python SOP that calculates the dimensions of an object.
Now I want to add a feature which enables the User to input a group prefix
(like piece*) and iterate through every single group object.
Can anybody give me an example on how to approach that ?
thanks,
Manuel
Iterating of groups with Python SOP
13047 16 5- asnowcappedromance
- 512 posts
- 512 posts
it's actually quite easy to do that.
In my Python SOP I got a parameter field (groupmask) in which
the user can type in a group mask (just like in the foreach SOP).
the code in the Python operator is as following:
sopnode = hou.pwd()
geo = hou.pwd().geometry()
input = sopnode.inputs().geometry().primGroups()
groupmask = sopnode.parm(“groupmask”).evalAsString()
for group in input:
string = group.name()
if string.find(groupmask) == 0:
print group
One thing that I couldn't work out - how would the code look like if I don't want to get an error message if the user inputs a wildcard?
something like “piece_*”
thanks,
Manu
sopnode = hou.pwd()
for group in input:
print group
thanks,
Manu
- dagush
- 98 posts
Probably with a regular expression (re)? Have a look at
http//docs.python.org/library/re.html
and use that instead of (string.find(groupmask) == 0) that you're actually using… I guess this could work.
best regards
dagush.-
best regards
dagush.-
* skylineEngine project coordinator
* buildingEngine module developer
http//ggg.udg.edu/skylineEngine
- graham
- 1922 posts
- 512 posts
- 512 posts
well maybe iterating through groups isn't that easy after all.
disregarding the whole wildcards thing, why is the following code
always outputting me the total number of points of ALL incoming groups instead of just outputting the total of every single one?
sopnode = hou.pwd()
for group in input:
newgeo = group.geometry()
print len(newgeo.iterPoints())
thanks!
sopnode = hou.pwd()
for group in input:
thanks!
- 512 posts
sopnode = hou.pwd()
for group in input:
thanks!
sopnode = hou.pwd()
for group in input:
thanks!
- edward
- 7899 posts
Because calling group.geometry() returns you the owner geometry object that contains the group, not a geometry object that only contains points from your group.
http://www.sidefx.com/docs/houdini11.1/hom/hou/PointGroup#geometry [sidefx.com]
I think you actually want to call group.points() instead.
http://www.sidefx.com/docs/houdini11.1/hom/hou/PointGroup#points [sidefx.com]
- 512 posts
- edward
- 7899 posts
- 512 posts
- 512 posts
ok, still struggeling, here's the next problem I ran into:
even if I'm inside a Python SOP operator, I get the following message
as soon as I'm trying to set an attribute value:
GeometryPermissionError: Geometry is read-only.
here's my code. (attempting to create a variable which returns the frame on when the primitives enter their group)
# This code is called when instances of this SOP cook.
sopnode = hou.pwd()
geo = sopnode.geometry()
# Add code to modify the contents of geo.
bool = 0
attrib = geo.addAttrib(hou.attribType.Prim, “onEnterGroup”, 0)
for group in input:
if bool == 0:
on_enter = hou.frame()
prims = group.prims()
for i in prims:
i.setAttribValue(attrib, on_enter)
bool = 1
thanks!
sopnode = hou.pwd()
bool = 0
for group in input:
if bool == 0:
for i in prims:
bool = 1
thanks!
- graham
- 1922 posts
All the processing you are doing is on the input geometry, not the geometry of the cooking node, so when you are trying to set your attribute, you are trying to set the value on the primitive in the input geometry, not on the geometry you have access to.
- Alejandro Echeverry
- 691 posts
Very nice thread!!!!
Thanks guys.
Thanks guys.
- 512 posts
- NSDesign
- 16 posts
graham
If you are using a recent build of Houdini 11.1 you can use the new hou.matchesPattern() function to handle it for you.
for group in input:
if hou.matchesPattern(group.name(), groupmask):
print group
I found the above python pattern matching function is incorrect. hou.matchesPattern(group.name(), groupmask)
The correct function is as follows:-
hou.patternMatch(groupmask, group.name())
http://www.sidefx.com/docs/houdini15.0/hom/hou/patternMatch [sidefx.com]
- grayOlorin
- 1799 posts
