python setPointFloatAttribValues question
   1714   2   0
hello there…
If I have a grid sop connected to a python sop I can modify the incoming grid sop's geometry with setPointFloatAttribValues through hou.pwd().geometry().
However, I'd like to modify two grids.
I've tried,
hou.cd('/obj/geo1/grid2')
geo2 = hou.pwd().geometry()
or
thisnode = hou.pwd()
inputs = thisnode.inputs()
geo2 = inputs.geometry()
and some other methods, but all attempts to edit the second geometry yields ‘GeometryPermissonError: Geometry is read-only.’
How can I modify the second geometry…?
You can only modify the geometry coming into your python sop. Could you create an attribute/group on each grid and merge them before your python sop, then edit them both with the python sop and split them apart after based on this attribute/group?
Both grid geometries are incoming through input and , respectively. Problem is, it seems only the first of them cooks.
Maybe I have to create two separate sops…
