color animation
   3418   2   0
Is it posible to animate color.
For a 3D power-plant there are a lot of pipes and for the flow of the products I like to animate this in color,
Is this posible? :?:
galinaton
Hi ,
yes you can animate colors .
in general , ALT+LeftMouseClick over any value input field creates a keyframe on that frame .
> ALT+LeftMouseClick into any of Color's input field values . ( you create a keyframe )
> move the timeline into another frame .
> change values ( of Color ) .
> ALT+LeftMouseClick over those again . ( you create another keyframe )
> now , move the timeline back and forth between those two frames .
.. color should be changing .
now and additionally , if you SHIFT+LeftMouseClick over the color's label , the Channel Editor comes in front with the the graph of changing values over time . you can further tweak it at your heart 's content ..
.cheers
except the things that cannot be seen , nothing is like it seems .
here is a very simple way to animate color going through a pipe using the Cd attribute; hope you find it useful
pipe_color.hipnc (730.5 KB)
