Hrender/commandline subframes?
   2576   2   0
Is there a way to render geo rop subframes from the command line?
hrender -i only seems to accept ints to skip frames, not generate subframes… am i missing something?
so currently, is the best way to load up the scene and use opparm -c?
- you could write a script that creates a .cmd file with the opparm for subframes and executes the hbatch/hrender,
- or you write your own little hython-script that loads the file and runs the given rop with the subframes, that could also check if the file is loaded correctly, if the node exists etc
Seb
