ROP output path expression
   3192   3   2
Hi everyone
I have an expression in my ROP output path. The expression looks like this
footageOutput(“test”)
and returns something like this
/Volumes/Vault/Local_Users/rcortes/Desktop/test/test.$F4.exr
The problem im having is that when I render any frame, the expression always resolves to
/Volumes/Vault/Local_Users/rcortes/Desktop/test/test.0001.exr
However if i delete the channel so that the expresion output becomes the output path, it works just fine.
I think that for some reason, the expression is being evaluated at frame 1 and the result is being cached and used for all other frames.
Does anyone know how I can get this to work? Is there a flag to force an expression to evaluate on every frame? (I thought expressions did this by default).
Much obliged.
rcortes
Rudy Cortes
TDChannel [tdchannel.com]
Hey, Rudy
Have you tried putting the expression on the “pre-frame script” field and relative reference it in the output?
Might force the script to re-evaluate every frame…
Cheers
Toronto - ON
rafaels
Hey, Rudy
Cheers
I thought about doing that, but I would really like to know the reason why the expression is not evaluated every frame and if there is a way to do so.
Cheers
Rudy Cortes
I found a solution
I wrapped the output path with a hou.expandString() right before I return from the function.
Cheers
Rudy
Rudy Cortes
