Hi all,
I have a question.
Why can I not place Normals (using the Point sop) on points generated from a Scatter sop from a Fog Volume generated out of an Iso Offset sop? I have a sneaky suspicion that it is because the points have no surface to frame their reference from.
I suppose, then, that instead of $NX, $NY, $NZ I need to use a st of expressions that will point the normals to the center of the spheres that I used to generate the fog volume. I'm not sure how to do that and was hoping for some help. Any suggestions would be appreciated. Thank you.
David
Scatter points from fog and Normals
2985 3 2- Barad_Dur
- 46 posts
- asnowcappedromance
- 512 posts
- sl0throp
- 258 posts
- Alejandro Echeverry
- 691 posts
Also you can calculate the gradient of the volume and then transfer to the point cloud the gradient vector.
