So I used to control the velocity and direction etc of my fluid emitters in Houdini 11 by using the velocity tab in the particlefluidemitter node.
As this node isn't part of the new fluid emitter setup in H12, I'm stuck on how to control the direction and velocity.
Any clues?
Huge thanks in advance.
H12 fluid emitter query
4366 4 1- chazfest
- 28 posts
- asnowcappedromance
- 512 posts
- chazfest
- 28 posts
- pwquint
- 53 posts
The velocity control is still there, just in a different place. Have a look at the SOP that you are using for your particle source. You'll find the shelf tool has created a node called create_surface_volume. This has several tabs, one is Velocity Volumes. This tab includes a tickbox for Add Velocity - you can then add a fixed velocity here. I attach an example.
Peter
Peter
Peter Quint
- chazfest
- 28 posts
