I've just started using pyro in 11.1 and am having issues with the flame not showing up at the object level when I turn off “emit smoke.” I can see the burn, heat and fuel guides in the dopnetwork, but can only see the smoke at the object level and see nothing at all when that is turned off. Any thoughts about what I might be missing? I'm sure it's something obvious but I just can't find it.
Also, does anyone have any tips on when to use the flames and burst into flames shelf tools and when to just set it up with a pyro container? What are the pros and cons of the different approaches?
hcs
Pyro FX problem: flames not showing at object level
2717 0 1- hcs
- 16 posts
