HDK removing duplicate points
   8399   2   2
I'm have problem to delete some duplicate points. I have a set of points and some of them have the same coordinates.
For simplicity, let's say I have 6 points, #1 and #3 are at the same place and #0 and #5 also. Just to be clear :
[imageshack.us]
I create 2 closed GEO_PrimPoly, one with points #2, 5 and 4 and the second with 4, 3 and 2. From that point, the triangles are at their “right” place. But then, I delete points #0 and 1 (gdp->deletePoint(#ofPOintToRemove, 1)) and the 2 triangles are broken :
[imageshack.us]
It seems that houdini is modifying the point number in order to avoid discontinuity but without updating the poly's vertex numbers. Or I'm doing something wrong ?
I've tried to use fastConsolidatePoints(), but I find this call to be kind of slow and redondant because in my algorithm I'm already searching for duplicate points and I know the index of the points not being use in any polys.
I know this is an old post, but I just ran into the same problem so I thought I'd share my answer: I also had some duplicate points with the same coordinates and fixed it using a fuse sop with “keep unused points” checked.
Hope that's helpful
lol… this 6 year old post ended my 2 days of search hail the fuse sop!
