I'm trying to interpolate between 2 rest fields but
am quite confused with the result.
I cached a sim out with rest and rest2 fields and the detail
attributes rest_ratio and rest2_ratio.
As far as I understand these are the weights which are used to blend these
two fields.
So I just picked up rest_ratio and used it to mix the 2 fields but the result
looks somewhat wrong. Do I need to mix these fields using the ratio or just need to switch these?
cheers.
Interpolating between Dual Rest Fields
3369 0 0- bhaveshpandey
- 127 posts
