Hey there,
So ive been exploring more of the Mantra Surface Shader and one thing i notice. If you dive into the network and edit the PhysicalSSS so that it operates in Physical Mode instead of artist, then none of the parameters at the SHOP level dont work anymore.
Is this by design?
I only just realized that the VOP has a bunch of presets and now that i am playing with them everything at the higher level is bypassed. ie Subsurface Color, Attenuation Color etc.
Is there a way to promote these parameters and presets since there is no way i will be able to remember exact Absorption Coefficient values. The presets seem to override all parameter connections.
-andrew
Mantra Surface VOP only in Artist mode on the PhysicalSSS?
2204 0 0- phrenzy84
- 249 posts
