help me with a python problem!
   2703   3   0
Hi all,
currently, I am working on characterRigging series and now am on inverseKIinCHOPsInAnAsset. The problem is that the python code according to the DVD doesn't work in my version, houdini12. This down below is the syntax.
channles = pwd().node(“../KIN_L_bone1”).tracks()
returnString = ‘ ’
for channel in channels:
splitName = channel.name().split('/')
newName = splitName
returnString += newName + ‘ ’
return returnString
But then after typing this code, an Error message that says “Unable to evaluate expression” pops up. I have a guess of the problem but am not sure.
After creating bones by inverse Kinematics, diving into a KIN Chops and laying down a rename sop, I need to type this code first at the To of the rename sop according to the DVD
returnString = ‘*’
return returnString
After that, if I click ‘toggle expression’ on the To of it, the color of blink is supposed to change but then it doesn't. So I just pushed alt + left click on it that changes the color. But I don't feel like it's a right method.
What could possibly be the problem in your opinion. Help me.
thanks.
Try right-clicking on the parameter and choosing Expression > Use Python (or something like that).
thanks! running expression by right-clicking is working, and yet, the syntax brings me an error message.
Error: Unable to evaluate expression (
File “<stdin>”, line 2, in expression
AttributeError: ‘NoneType’ object has no attribute ‘tracks’
(/obj/KIN_Chops/rename1/renameto)).
Warning: This CHOP has no effect.
Do you have any idea?
It looks like you function call to node() didn't find a node.
