Baking lighting with mantra
   Views 2177   Replies 0   Subscribers 0
Hi everybody
I was trying to bake som lighting onto a texture with the mantra command -u /obj/“Something”, but it seems as if the normals go beserk on me, whenever i use a shader, which actually shades the model. If i use a simple constant material the map renders just fine, so is there a specific shader, which i should use or is the mistake coming from elsewhere. (I have UV's, light and camera in the scene).
