flip fluid tank question
   Views 3036   Replies 2   Subscribers 0
Hi everybody!
I faced a situation that i believe is really easy to solve, but i have no idea how exactly.
I need to make an ocean surface, and i'm creating flip fluid tank for that, but the fluid is interacting with the walls of a tank. Ofc i want to remove this effect, so i uncheck bounding box for the fluid exept y. And the result that i get is that all the fluid goes away from the sides, and dissapears.
And i want to make constant amount of fluid in a tank, but just not interacting with the walls. Exactly like in realflow or like is this video https://vimeo.com/40215700 [vimeo.com]
So do you guys know that is the way do to it?
Try to mimic it width animated procedural texture. Or play width simulations without turning off the boundaries. Liquid must go away without boundaries - it's just spreads out because of gravity force.
yes i understand that it comes from gravity, i'm just wondering what is the way for the liquid to act as liquid but not spread away.
