Since upgrading to Lion Houdini help has failed. Nothing I do will get it to work following this thread http://www.sidefx.co/index.php?option=com_forum&Itemid=172&page=viewtopic&t=26030 [sidefx.co] coupled with icons unable to build because Houdini is referencing the wrong Python libraries
File “<stdin>”, line 1, in <module>
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/houdini/python2.6libs/houdinihelp/__init__.py”, line 40, in <module>
from houdinihelp.wiki import WIKI, page_to_html, string_to_html, string_to_xml
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/houdini/python2.6libs/houdinihelp/wiki.py”, line 10, in <module>
from wikiparser.filters.trees import (block_attribute_elements, color_syntax,
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/houdini/python2.6libs/wikiparser/filters/trees.py”, line 20, in <module>
from pygments.lexers import get_lexer_by_name
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pygments/lexers/__init__.py”, line 21, in <module>
from pygments.plugin import find_plugin_lexers
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pygments/plugin.py”, line 39, in <module>
import pkg_resources
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pkg_resources.py”, line 657, in <module>
class Environment(object):
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pkg_resources.py”, line 660, in Environment
def __init__(self, search_path=None, platform=get_supported_platform(), python=PY_MAJOR):
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pkg_resources.py”, line 55, in get_supported_platform
plat = get_build_platform(); m = macosVersionString.match(plat)
File “/Library/Frameworks/Houdini.framework/Versions/12.0.670/Resources/python/lib/python2.6/site-packages/pkg_resources.py”, line 187, in get_build_platform
plat = get_platform()
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/util.py”, line 98, in get_platform
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/sysconfig.py”, line 537, in get_config_vars
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/distutils/sysconfig.py”, line 405, in _init_posix
DistutilsPlatformError: invalid Python installation: unable to open /usr/include/python2.6/pyconfig.h (No such file or directory)
I did have a prior build of X tools on 10.6 snow leopard and upgraded the OS to Lion via the app store. Users who never had x tools installed prior to lion do not seem to have any problems. So I am just wondering if anyone else has had this issue and does anyone happen to know how to remove x tools completely and maybe doing a OS repair / reset while leaving all the data intact.
Rob
osx 10.7 Houdini firefox help failure
2842 2 0- circusmonkey
- 2624 posts
- kjmitch
- 23 posts
You might want to have a look at this particular topic:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22368&postdays=0&postorder=asc&start=50 [sidefx.com]
I had a mac pro and like you once I upgraded to lion the Houdini help function was broken. I tried many things listed online to resolve the issue, but nothing helped. I'm not sure if you can downgrade and keep everything in tact as I've never tried it personally.
- circusmonkey
- 2624 posts
Well one thing is clear. There is an issue with Houdini and how the help functions on OSX , its never really been that great and has always thrown problems up.
But After 2 days with this annoying issue I have managed to fix it .
http://www.circusmonkey.com.au/circusmonkey/OSXLION.html [circusmonkey.com.au]
Rob
Rob
Gone fishing
