checkActivation in HDK12 always failing
   1488   0   1
hi,
i'm trying to write a POP plugin in HDK 12.
i'm starting by compiling the sample POP node that came in toolkit samples… however, when I compile and install the samples (POP_LocalForce, POP_CircleForce, POP_SpotLight)… none of them evaluate correctly and checkActivation is always returning 0 even when activate parameter returns 1.
so it fails on this line…
if (!checkActivation(data, (POP_FParam) &POP_CircleForce::ACTIVATE))
if i comment those lines out so they always evaluate then it seems to work properly…
any help would be much appreciated…
thanks,
alex
