How to call python2.5 in houdini 12?
   4473   4   3
In the Windows operating system,houdini12 uses python2.6,but now I need to call python2.5, Is there somebody knows how to do this?
And what are the detailed steps to do this?
It will be greatly appreciated for your help.
Thanks again!
$ hconfig -h HOUDINI_PYTHON_LIB
HOUDINI_PYTHON_LIB
The Python library that Houdini should load at startup. By default,
Houdini searches for a suitable Python library in the system's
standard locations and falls back to the library in $HFS if none
can be found. Setting this variable overrides that behaviour.
EDIT: I think you give it a path to the python25.dll
edward
HOUDINI_PYTHON_LIB
Thank you very much, edward !!
I am trying to work it out now.I really appreciate your help.
Thanks a million times.
Is there a reason why Houdini doesn't use Python 3.x?
hopbin9
My understanding is because most studios' pipelines are glued together with python scripts that were written years ago and converting python scripts from 2.x to 3.x can be more than trivial. It is the same reason that Maya's shipped python version is a similar one to Houdini's, and why I'm pretty sure PRMan's python bindings only work with 2.x, etc.. Once larger studios move to 3.x, so will Houdini, along with every other major CG package.
If you write your python scripts intelligently by never using deprecated features and using “from __future__ import (replacement feature X)” as much as possible, your scripts should be fairly easy to convert when the time comes that 3.x is supported.
