OTL asset problems
   1124   0   0
A simple tool that reads hair data > does some math and spits out a float result.
Drop the otl down and plug it into the fur object. It should give a result like the other nodes plugged in. It does not . unlock the asset > then RMB and match the current definition and the asset will now work. I assume this is a refresh issue of sorts with the objpath1 parameter . Can anyone tell me why this happens ?
Rob
rse_haircounter_example.hip (1.6 MB)
rse_hair_counter_v001.otl (8.5 KB)
Gone fishing
