I am attempting to package up various SOP plugins which has an SVG icon.
My installation script will put the files in some non-Houdini location e.g. /usr/local/mypackage/houdini
Under that installation directory, I have a dso and config/Icons subdirectory.
Through the use of HOUDINI_DSO_PATH, Houdini was able to find the custom SOPs but not the Icons associated with the SOP.
I am debugging the problem on Linux.
Any pointer as to how one should specify the environment variable to get Houdini to pick up the custom icons ?
I am currently using Houdini 12.1.94
Regards
HOUDINI_UI_ICON_PATH definition for plugin package installer
1770 0 0- nicholas_yue
- 301 posts
