Hi all,
My problem
Fatal error : segmentation fault
file saved to directory
I have been looking around to fix this problem. Some things that I tried:
1. changed the 3D viewport to GL 2
2. add the HOUDINI_OGL_SOFTWARE with var of 1 to the env system
3. deleted all .pref files in $HOME/Houdini12.1
unfortunately none of the above could fix my error.
Intel(R) Xeon(R) CPU E502660 0 @ 2.20 Ghz 2.20 Ghz
32 GB
64 bit
Windows 7 Professional
The thing is, it only occurs for this particular file that I have which includes: particles, smokes, fireball pyro, and RBD simulation. Maybe some of these has effect on it?
However, I tried to run the same one from OSX and it does not have any problem with it and it could work just fine. It occurs when I tried to work from Windows.
Anyone have any solutions in mind? I have looked through most of the posts about it but maybe I missed something?
any help will be greatly appreciated, thanks!
Fatal Error : Segmentation Fault in Houdini 12.1
2607 0 1- mottchzee
- 3 posts
