scale minimum distance offset by attribute
   1314   0   0
is there anyway to scale the offset of a minimum distance sdf by either a point or prim attrib?
the only way i can think to do it outside of building the volume from points would be to make a minimum dist sdf with an arbitrary offset, and then grab each points attrib and add or subtract that from the current value in each voxel. ill give that a shot tonight, but was wondering if there is a more straight forward solution.
thanks
