Hey guys
im having problems seeing icons on my nodes, ive tried previous threads on the forum but none of them provided a solution for me.
Does anyone know how to resolve this issue.
This is the console output i get when i run houdini:
linuxopt/hfs12.5.371 # Warning: program compiled against libxml 209 using older 207
/opt/hfs12.5.371/hsvg/hsvg: line 7: /hsvg/hsvg-bin: No such file or directory
it seems that houdini is trying to use an older version of the libxml or is linked to different version
icons not showing up houdini 12.5 opensuse 12.3
6674 6 1- nosferatu037
- 39 posts
- goldleaf
- スタッフ
- 4200 posts
- wolfwood
- 4271 posts
- edward
- 7899 posts
- nosferatu037
- 39 posts
Wolfwood
Might be because Houdini is picking up the system's Python 2.7 libraries instead of its own.
Try setting-
export HOUDINI_PYTHON_BIN=$HFS/python/bin/python2.6
export HOUDINI_PYTHON_LIB=$HFS/python/lib/libpython2.6.so
In your bashrc assuming $HFS is defined at that point.
Thanks wolfwood that was the issue.
AS soon as i set the houdini python env everything strated working fine.
cheers
- mzigaib
- 978 posts
Wolfwood
Try setting-
How can I do it in windows?
- Neil78
- 275 posts
Hi Guys -
I just ran into this problem - on mint 15 -
and sure enough setting the env to point at Houdini's Python did the trick
Thansk for the help Wolfwood - but can someone explain to a linux newbie like me, why Houdini is not looking at its own python libs to begin with? - Is this something to do with the way the OS (mint 15 in my case) defines how programs should use their own libraris?
Im curious
Im curious
