TRS Asset crashing
   14756   9   0
http://www.orbolt.com/asset/VFX_MZM::TRS#4 [orbolt.com]
I bought the commercial version of that asset. I tried TRS on windows7_x64.
It seems to crash on all my H12.5 versions. Is anyone else having the same issue ?
If I drag the TRS asset in the viewport, I can use it with the provided primitives, although on 12.5 the rotation effects do not seem to work (while it does on 12.1). It also seems very slow compared to the video linked on the asset page.
If I use the tab menu to add the asset in a SOP node, it just crashes.
Tried with 12.5.372, 12.5.316.22
Hi br1,
I was able to reproduce the issue, and have emailed the author with a way to correct it. Once a new version is uploaded to Orbolt, you'll be able to update and get the fix.
Adam
Hey Adam,
Thanks a lot for giving this some attention.
Let's hope it gets fixed soon as I'd be glad to use that asset in the coming days..
br1
Hey Adam,
Thank you to buy it ,although I receive nothing :cry: 。
about the speed,try to use “lock”and“lock piece”,and it running normally on my H12.5(12.5.371)
I think I found why it crashes here. If I start fresh your asset goes into “Uninstalled Assets” in the Tab menu. If I go the the Asset Browser, right-click and choose “Install OTL only”, then the asset goes in MZMAssets and stops crashing Houdini.
Hi again…
Although the asset doesn't crash with the method in the previous comment, it's sill far from working like on your Vimeo demo.
- It's still extremely slow, even with a basic cube and 4x4 divisions.
- Although translate and scale effects work, nothing seems to affect the rotation. It's just not moving if rotation is the only active effect.
This is wit 12.5.379. Again the rotation effect works with 12.1.185.
Can someone confirm that issue ?
br1
Hi again…
The new version has been uploaded~~
It will soon be able to download
fyi the new version is up on Orbolt
I hate to say, but it's still extremely slow on my computer, which makes the asset totally unusable, even with lock, lock sort and lock piece.
using Houdini 12.5.411
You can find critical diseases particularly need to be was able.
