:!: houdini 12.5 on opensuse 12.3
   1736   0   0
Hey guys
I managed to install opensuse 12.3 on my machine and ive downloaded houdini 12.5 and installed it, however i do have quite a lot of problems running it.
Ive started a thread about the icon issues, but it seems that its not the only problem.
It seems that when i load houdini_setup_bash and run houdini all the other applications in -$HFS folder are not getting the env variable properly.
The only way i managed to run houdini with proper loading of icons is if i su and change the hsvg bash script and substitute $HFS with /opt/hfs.x.xxx, so an absolute path
I also cannot run mplay from houdinii to open or flipbook to work.
Houdini just hangs until i hit esc and it takes a while for it to register the key, and in console i get a msg
Spawn Error: : No such file or directory
Error running mplay
Argument list:
0: mplay
1: -flipbook
it seems that mplay.sh is not being executed properly.
This happens if i run houdini by clicking on the icon or if i run it from console.
Can someone help me figure this one out.
cheers
