Mac OSX Mountain Lion upgrade - cant launch houdini
   5822   5   2
Hi.
I upgraded from Snow Leopard(10.6) yesterday, to Mountain Lion (10.8.3)
Now houdini will not launch. I am getting a large list of continuous errors, that seem to think my Mac is 32 bit architecture.
But its a Core 2 Duo (and also h12.5 and earlier - all worked fine on 10.6
Any ideas ? Id hate to have to revert back…
Heres some of the errors:
The Houdini 12.5.316.22 environment has been initialized.
“/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/math.so: no appropriate 64-bit architecture (see \”man python\“ for running in 32-bit mode)”
“Traceback (most recent call last):
File \”<stdin>\“, line 2, in <module>
ImportError: /Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/math.so: no appropriate 64-bit architecture (see \”man python\“ for running in 32-bit mode)
File “<string>”, line 3, in <module>
File “/Library/Frameworks/Houdini.framework/Versions/12.5.316.22/Resources/houdini/python2.6libs/hou.py”, line 37401, in <module>
__finishImport()
File “/Library/Frameworks/Houdini.framework/Versions/12.5.316.22/Resources/houdini/python2.6libs/hou.py”, line 37319, in __finishImport
Vector2.almostEqual = __deprecated(Vector2.almostEqual)
File “/Library/Frameworks/Houdini.framework/Versions/12.5.316.22/Resources/houdini/python2.6libs/hou.py”, line 37254, in __deprecated
import warnings, functools
File “/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/functools.py”, line 10, in <module>
from _functools import partial, reduce
ImportError: /Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/_functools.so: no appropriate 64-bit architecture (see “man python” for running in 32-bit mode)
PyClerk: Traceback (most recent call last):
File “<stdin>”, line 1, in <module>
File “/Library/Frameworks/Houdini.framework/Versions/12.5.316.22/Resources/houdini/python2.6libs/shopclerks/i3dclerk.py”, line 5, in <module>
import hou
__finishImport()
I'm probably wrong but could the build you downloaded be responsible? I notice there are gcc (10.7) and clang (10.8) builds available.
Thats a horrifying possibility. Thanks. I am actually running the 10.7 build …
so am downloading the 10.8 build now.
However - this means that none of the earlier houdinis will run on 10.8 - disastrous !!
I will check if this fixes the issue, and report back. AND then have to reinstall my mac back to Snow Leopard or 10.7 (lion ?).
Starting to regret using a Mac now …
So installed the 12.5.376 build for 10.8
and rebooted.
Same errors!“/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload/math.so: no appropriate 64-bit architecture (see \”man python\“ for running in 32-bit mode)”
File \”<stdin>\", line 2, in <module>
Im now going to take the Mac BACK to 10.5 then to 10.6
any solution to this? was going to upgrade the studio I work at to 10.8 next week, but not if I cant get the artists on 12.5
I've a Mac Pro and Mac mini happily running the latest daily builds and latest os X version 10.8.3
Not sure that the issue is but what model of Mac are you running? There some that can be booted in 32 or 64 bit etc.
http://support.apple.com/kb/HT3773 [support.apple.com]
