Volume Motion Blur!
   3487   1   2
Hey all -
I've been trying to get motion blur on my volumes, and have followed the directions in this post exactly:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22128&highlight=volume+motion+blur [sidefx.com]
However, it's not working. I can open up that posted project and see it fine, however if I try to re-create it I get no results.
Here's a simple project file - a spherical volume, spinning around an axis, then a point cloud made with v calculated, and passed to a vel volume. Can anyone help me figure out what's wrong here?
Thanks.
-Mike
volumeMotionBlur.hipnc (203.5 KB)
If you check the parameter “Geometry Velocity Blur”, in the render>sampling tab it should work.
Now I'm not clear if you said it doesn't work because that parameter was off or because you were expecting different result…
Cheers
Toronto - ON
