just want these spheres behave independent
   Views 2540   Replies 2   Subscribers 1
why are these speheres not act independent of each others.why they behave like a cube?
spheres.hipnc (243.4 KB)
スタッフ
The RBD Object DOP will create a single RBD Object from the entire source geometry, which causes the spheres to behave as one object.
For the effect you want, you can use the RBD Point Object DOP to create a separate RBD Object at each point of some source geometry. I've attached an example demonstrating how this can be done.
spheres_516.hipnc (244.2 KB)
Thank you very much
