Hi, so I'm following some tutorials from sidefx and I was just wondering if it's possible to use a volume with volume from attribute SOP (transfering point normals to volume) to drive a fluid simulation? I used the volcano tutorial from sidefx's vimeo page as a guide. That means, I used Source Volume with volumeSOP (with points normals). But the problem I'm having is the simulation is different from this Source VolumeDOP.
The volumeTrailSop shows different direction. The input I was using in volumeVOP is Position then output to parameter named vel.
I have used the same volume with point normals to drive a popnet sim and it worked.
So basically, I have a volume with points normal attributes transferred using volumeFromAttributeSOP. I want to use that to direct my smoke sim.
I appreciate any help thank you.
Fluid velocity with volume, points
2123 0 0- icerust
- 68 posts
