Hi, my system drive (windows) gets full in the middle of rendering out 72 frame bgeo using import_uprespyrofields Dop I/O. I have about 50gb of free disk space in the system drive. I'm using another drive to write out bgeo files.
Lowres' load from disk is On. Max division is 318.
Hi-res is set to 618.
I used Explosion and Upres volume shelf tools.
I thought it was caching. So I switch Off Cache Simulation to Disk and Cache Simulation in the AutoDopNetwork node. That doesn't solve it.
On another issue, how do I continue writing out bgeo if I stopped at say frame 32? Do I need to use a file node and another bgeo render?
I rendered out the volumes using Mantra and it worked well for those written frames.
Thank you very much and I appreciate your help and time.
Cache issues, rendering bgeo of upres pyro
2290 0 0- icerust
- 68 posts
