error while synchronizing child node fireball shader
   5962   5   1
I'm having an issue while using the fireball shader. When i use it and twant to re open my scene, it displays opening error: problem while synchronizing child node and skipping unrecognized parameter.
Already tried with a new scene, same error and deleting the Houdini 13.0 folder, still got the messages.
Any ideas?
using the latest build and drivers up to date
fireball_shader_problem.hip (1.2 MB)
Perhaps log a bug.
posted a log this morning, hope this will be fixed
Which build are you using? Seems to be fixed in .233.
“Houdini 13.0.233: Fixed a bug where Houdini reported ‘unrecognized parameter’ warnings when loading .hip files that contained the Dual Rest VOP or Pyro Field VOP. These VOPs are heavily used in the Pyro FX shelf tools.”
I whas using .231 when I posted the msg, will download the new build asap
Edit: went to the daily builds to download it but it isn't herre. Any idea where I can get it?
I am also getting the same error. I am using 13.0.288
Warning: Problem while synchronizing child node:
Warning: Skipping unrecognized parameter “folder1”.
[/shop/flames_not_used/SmokeColor/Color/if_usecd_tint_with_cd/Cd
Is it fixed in latest build?
Thanks,
@@KaRe@@
