Interaction between two Flip Fluid objects ?
   5459   1   1
I´m trying create a Flip Fluid from two objects to interact with each other.
Somehow I can´s seem to get it done. I looked at the example file
“DensityViscosity” where a FlipTank and SourceVolume is used. But
I can´t seem to recreate the effect with two Flip Objects. So basically
what I want to do is having two spheres defined as Fluid with different
density/viscosity interacting with each other within one Grid. Like both
splashing into a closed grid.
I tried to create two Flip Fluid objects and set them up as in the
“DensityViscosity” example. I used a merger after two Flipsolver
as well as a merger to merge both flipfluid objects before the solver.
Also I tried several collision options without success.
Any pointer into the right direction is much appreciated.
You want one flip object, one flip solver, with multiple emitters. You can also do one emitter, and just vary the point attribute values in sops first.
Ian Farnsworth
