Hi everyone,
I animated an object (a bottle), and my goal is to emitt fire from this bottle. Of course it is moving too fast, so it's complicated for it to emitting fire. I checked some topics about the subject, and I think that my problem is alsow coming from the fact that it's animated by “hand”, so it's only $F. On this image I added a trail sop, and this is the maximum “inter” object that I can have.
Is there a way to convert $F in $FF ? I just need some other frames between the actual frames.
Thanks !
Convert $F to $FF ?
2898 5 1- Lewul
- 250 posts
- buki
- 1773 posts
hi!
the timeblend sop should provide you with interpolated geometries between integer frames, when you set substeps on dop network
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- Lewul
- 250 posts
- Lewul
- 250 posts
- Sadjad Rabiee
- 1391 posts
I checked your file ,In this project you don't need to convert $F to $FF with “TimeBlend SOP” !
When you use keyframe Animation ,Your animation data is $FF ,Just check Animation Graph in the “Channel Editor” window ,The Curves are really smoothly !
for example check Curve's Graph images on this Topic :
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=142400#142400 [sidefx.com]
When our animation data is $F ,So Animation Graph is not smooth (Like the Images on the above Topic)
If you wanna fill free space between bottles ,you should decrease “Trail Increment” parameter for “Trail SOP” :?
- Lewul
- 250 posts
