Hey everyone,
I was looking for a quick (read: lazy) way to promote the parameters of the unified noise vop to top level of an HDA.
I thought I struck gold with this:
def createNoiseUI(parent):
b = parent.parmTemplateGroup()
if b.find('noise1group'):
b.remove('noise1group')
cPath = parent.path() + ‘/input/volumevop1’
cNode = hou.node(cPath)
cParm = cNode.parmTemplateGroup().find('noise1group')
b.insertAfter('sepparm3', cParm)
parent.setParmTemplateGroup(b)
Of course, my success was short lived as I now needed an equally clever way to link those parameters to the ones buried deep within the asset.
Is there a clever way to do this without having to harden the parms and linking manually?
G
Promoting unified noise parms to top level of HDA
4077 2 1- keyframe
- 1533 posts
- wolfwood
- 4271 posts
One option is to use the Import Settings option on your HDA. You specify a node and a parm group. Then in the little gear box option there is an option to “refresh imports” which will rebuild those links. Works pretty well. Sadly its a UI only action at the moment as there is no HOM method that exposes that functionality.
There is an RFE for it tho….
ID: 25143 - Created: 81 Months Ago
:wink:
:wink:
- graham
- 1922 posts
