stamp with particle attributes
   7800   8   2
Hi all,
I have a question in H13.
I try to copy an object to points of particles.
and scale this object with attribute of particles like AGE by stamping.
I attached simple test Hip file.
As you see particles have non zero value for AGE.
but stamping do not work well.
hope someone could give me some advice ?
Thanks,
takahiro )
Edited by - 2014年3月12日 22:16:29
age.hip (278.3 KB)
Hi Takahiro,
You just found a bug. It seems the attributes created by the new POPs is causing the Copy SOP's stamp function some confusion.
If I use the old POP Network and create particles, your example works right away.
If you need this to work in the meantime, you can reference age with a point() function in the Stamp SOP.
Please submit a bug report through the Support > Submit Bugs and RFEs link above.
Cheers!
steven
While this may be a bug, I would suggest using pscale on the particles to scale the geometry. You can create a pscale attribute using age on the particles themselves, and the copy sop will read pscale and use that as a multiplier when copying.
Ian Farnsworth
Hi,steven and Ian,
Thank you for giving me so much useful advice.
I have just submitted bugs reports and can start new approch today!
I'm happy now.
Thanks,
Takahiro
Temporary you can use this way : :?
JKAge.hip (292.1 KB)
Rabiee.Sadjad@Gmail.Com
Hi,Joker386
your popvop usage is a very nice help for me!
thanks,
Takahiro
fujii
Hi,Joker386
thanks,
Takahiro
:wink:
Or alternatively, you can pass age through as an attribute rather than a variable in the ‘attribute stamps’ field. Check out this example.
IG_age.hip (281.1 KB)
Hi,Ilan
Your alternative idea is very nice!
Sorry for not replying sooner.
Thank you so much.
takahiro
