Random Text on every frame
   4943   7   4
I'm trying to generate a visual matrix of letters. Each letter should change on every frame. I've attached a file in which the system works partially. It either changes all letters to the same letter on every frame or changes all the letters on the matrix once but does not change in time. I'm using a stamp in the copy node to modify a substring. In other words, Is this possible?
Letters.hipnc (163.5 KB)
M.J
Hi, you were close, to make a random letter appear at each frame on each point you needed to randomize the point and them simply multiply by $FF. I must admit I find it easier to build my random attributes in vops on the actual points, to visualize values in the details view.
Rob
letters_176_fixed_rse.hipnc (168.8 KB)
Gone fishing
Thank you.
M.J
Also you can make another effect exactly like “Matrix” movie with some little changes on your project :idea:
In this case each new word falling down after generation , something like waterfall , Check attached file :
JKletters_Type2.hipnc (198.4 KB)
Rabiee.Sadjad@Gmail.Com
Any solutions for Houdini 19.5? Because copy sop is not there anymore! Thank you
zaahead
I'll bet if you searched the 19.5 docs for copy sop you'd find the information you're looking for.
I could just tell you, but ya know....teach a man to fish...
Good luck!
スタッフ
The Copy to Points SOP has a very handy "Piece Attribute" which allows you to specify which incoming piece of geometry to instance at the given point location (as long as both the points and the geo have the same attribute).
Here's a quick example.
CopyToPointsMatrix.hip (134.6 KB)
npetit
This is great, Nick. Thank you
