I must not be understanding something here. Why when I use this expression in the Z rotation channel of a transform SOP, does it return -45, when I am expecting it to return 90?
explodematrix(mlookat("“,”“), ”RST“, ”XYZ“, ”RZ")
I just want to rotate an object from one unit vector to another. Thanks for any tips!
rotation between two vectors
3831 3 2- grhart
- 21 posts
- tamte
- 8833 posts
if you want rotation matrix from one vector to another use dihedral()
so it'll be
explodematrix(dihedral("“,”“), ”RST“, ”XYZ“, ”RZ")
(as mlookat() and mlookatup() are for creating rotation matrix in direction from one vector to another with optional up vector, so in case you use them your first vector would ideally be for origin)
so it'll be
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- grhart
- 21 posts
- pelos
- 621 posts
