zdepth shader using vops?
   3503   0   1
Is it possible to create a zdepth shader using VOPs that can be applied as a surface shader to a piece of geometry and then rendered as an image render in place of a zdepth deep raster render?
I did this before where I created a surface position shader and applied it and rendered it, and it came out the same as a surface position deep raster render.
Is this possible?
-jon
