Anyone have any good examples of how the State and Suppress POP are used? I have been playing around with them, especially the Suppress POP. Now when you set say Position parameter to 1 in Suppress POP that means it should instantly stop incomming particle groups from moving, suspended? But it doesn't seem to work as I expect it…any ideas?
Yes, turning on Suppress Position in the Suppress POP should prevent the timestep from updating the particle position using the velocity. What do you mean when you say it doesn't work as you expect it to?
