ROP OutPut Driver/H14/non-Commercial Edition vs inst
   12891   4   2
Hello, Go Procedural tutorial, “Quick Start” say to drop down a ROP output driver node and output BGOE files. However, the node errors as I have a non-commercial licence. Have I mis-understood the instruction or is the instruction not suitable for beginners who i expect like me will be using non-commercial licences in the majority of instance?
MMB on the node and please advise what the error is. Could it be your resolution size , incorrect path for your output file ? .
rob
Gone fishing
EricGarlic .
The noncommerial and limited commercial versions have a different file suffix .bgeo.sc for noncommercial. you might need to edit that in the rop.
スタッフ
OneBigTree
EricGarlic .
Clarification.
Actually, bgeo.sc is compressed .bgeo file (using BLOSC compression). These are often as fast (or faster) to read/write than plain .bgeo files, and take less disk space.
I don't believe that Apprentice encodes .bgeo files.
mark
OneBigTree
EricGarlic .
Clarification.
Ah ok, have only seen the .sc in apprentice. I had a similar problem in a tutorial, where I was writing out bgeo.sc files but a fetchnode somewhere was looking for .bgeo I think it was Ocean wavetank tutorial.
Edit: I checked, it was the texturemap export from the wave tank. Apprentice exports picnc (hence the confusion). The fetchnode looks for .pic. So maybe not the solution for the original question
