I seem to run into this issue a lot.
I create a line of points, and then use the sort $TX-$TX2 .. trick to get all the normals pointing down the line (which is never a straight line down an axis . The heading and pitch are fine, but the “bank” is very often not what I want. Which is obvious when I begin to copy geo to those points and things are rolling some arbitrary amount.
I have tried using things like polyframe, and even blending normals from two sources with a vop sop without much success.
Is there some sort of “up vector” trick I don't know of. I seem to always be able to only get 2 of the 3 orientations of the normal how I want.
Thanks for any suggestions.
Orienting normals
3100 5 2- Kfinla
- 100 posts
- circusmonkey
- 2624 posts
Hi
Check out some of my notes http://www.circusmonkey.com.au/circusmonkey/Sops.html [circusmonkey.com.au]
Rob
Rob
Gone fishing
- Kfinla
- 100 posts
Thanks, lots of good info there.
I'm still not really getting what I want thought.
Basically what I want to do is have the normals flow down the mesh. I know of a trick using a vop sop and two cross-products, but again.. some work some don't.
Maybe its a stamping issue. I'm just doing a vanilla copy.. so perhaps I need to find a way to have each copy orient itself since a one size fits all transform on the mesh I am copying can only ever have some of the geo oriented properly.. ie. the chest is good, the arms are not in this example.
Any ideas?
Any ideas?
- dan.baciu
- 30 posts
You are aware that to have a complete description of orientation you need at least a normal and an up vector. The normal should point along the curve and the up vector defines the direction perpendicular to the curve in this case.
Looky here: http://www.sidefx.com/docs/houdini14.0/copy/instanceattrs [sidefx.com]
- koen
- 793 posts
The easy way is to abuse a sweep sop, I attached an example. It also is not hard to implement a moving frame in a python sop, but that takes a bit more figuring out. Here is some nice information:
http://research.microsoft.com/en-us/um/people/yangliu/publication/computation%20of%20rotation%20minimizing%20frames.pdf
[research.microsoft.com]
Hope that helps,
koen
Hope that helps,
koen
- Kfinla
- 100 posts
