No more Loop "L key" selection for edge in Houdini
   3930   3   1
Hi guys,
If you know the Loop function in Houdini 14, please let me know. I used to use it a lot in 13. Seems like it doesn't work.
スタッフ
https://www.sidefx.com/index.php?option=com_content&task=view&id=3023&Itemid=404 [sidefx.com]
Training Lead
www.sidefx.com
Thank you for the video link, but seems like it doesn't work with triangulated meshes. I just want to select outside edges of a obj.
スタッフ
If you need to select outside edges procedurally, the Group SOP set to Unshared Edges, like the screenshot shows (make sure you uncheck Enable under the Numbers tab, which is on by default).
Also, if the new edge loop select doesn't work with a mesh, send a bug report to sidefx with the mesh if possible. Might be a bug?
I'm o.d.d.
