size discrepency
   3378   2   0
Hello, I just downloaded and installed latest houdini /engine plugin. I created a simple asset using a plane which is UVed and that's basically it. The only control parameter right now is size, which I have default to 1.
When I bring this asset to UE4 the generated mesh size was unexpected, I was expecting either 1, 10, or multiple of, but my default plane baked at 50x50 cm, thought this was kinda odd.
Bug or something I'm missing?
Thank you
basic_uved_plane.hdanc (3.7 KB)
Hello Eric!
We provide scaling option in Edit->Project Settings->Houdini Engine (Geometry Scaling and Import) section. Adjust it and re-import the asset.
Hope this helps!
I completely missed those plugin settings, that worked, thank you!
