I need to touch some skinning weights inside a SOP graph.
I tried using a point wrangle but I can't get the syntax for accessing the boneCapture attribute right.
Does anyone know how to write to the boneCapture attribute using vex?
Is there a better way of just flagging a group of points to belong to a different bone?
Overriding skinning information in SOP
3372 4 0- David Larsson
- 32 posts
- David Larsson
- 32 posts
- atnx
- 2 posts
- NicTanghe
- 210 posts
How thanks allot for replying to this after 6 years right before i need the info.
I'm looking to rename my segment from L_* to R_* and capture mirror attribute isn’t working.
It seems that you can't really change or ad bone capture regn names, only the indexes, which doesn’t really help here.
Edited by NicTanghe - 2024年6月1日 14:13:56
- tamte
- 8785 posts
You can use Attribute String Edit to rename the region names within the boneCapture attribute
Just specify the attribute name as boneCapture* or directly as boneCapture.pCaptPath for it to work
NicTangheOr if you really want to use the unpacked attribute, the region names are stored in a Detail attribute where you can edit them
It seems that you cant really change or ad bone capture regn names only the indexes wich doesn`t really help here.
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
