CHOP export TouchDesigner to Houdini
   5299   5   2
I captured coordonnees with kinect or leap motion from Touch Designer.
And i want bring this to Houdini for add VFX on it, but i try to export every format : .clip.chan.bclip.bchan.aiff.wav
And only .chan can be read, but Channel name are reset. :cry:
i don't know if the probleme come from Houdini or Touch, but i thought they was old friends !
From Houdini to Touch. extension . clip works like charm.
Here my .chan (supp .hip), if someone wanna try.
TD_to_HD_bullyChop.chan.hip (3.7 KB)
Your file is named td_to_hd_bullychop.chan_303.hip but it is not a hip file but .chan file. I changed the name to td_to_hd_bullychop.chan and imported into a chop network in Houdini with a file chop and everything was fine. I have shared .chan files between, Touch, Houdini and Nuke without every really encountering an issue.
(yes i have renamed .hip, because the forum didn't want upload .chan)
As you saw, he don't keep channels names.
Do you have a technique to keep the names ?
Thx
i don't know, why he don't want read .clip ?
TD_to_HD_bullyChop.clip.hip (3.9 KB)
Please, did you manage to import channels with names from TD to H?
I have tried to investigate and there are small differencies in .clip as Houdini and Touchdesigner creates them. Please, can anybody help?
Houdini:
rate = 24
start = 0
tracklength = 240
tracks = 1
name = chan1
data = 0 0.25881904363632202 0.5 0.70710676908493042 0.86602538824081421
Touchdesigner:
rate = 60
start = 0
tracklength = 600
tracks = 1
name = accxyz1
data_rle = -0.00669861 @2 -0.00994873 0.000991821 @2
Rob from Derivative helped me here:
https://www.derivative.ca/Forum/viewtopic.php?f=4&t=7959&p=39829#p39829 [www.derivative.ca]
