Custom ROP act like subnet/network
   1311   0   1
I'm trying to create a custom ROP_Node implementation that works like a subnet. I want the user to be able to dive into the node and add a select set of stock ROP nodes. The node will expose a couple of simple parameters.
I've subclassed ROP_Node and overridden isNetwork to return 1. I've also created a custom OP_OperatorFilter to expose only the nodes I want allowed internally in the node.
This allows me to create the node in houdini and dive into it, but I'm unable to add any nodes inside. I get permission errors whenever trying to do this.
I've tried changing the flag when adding the node to operator table in newDriverOperator(). I've tried OP_FLAG_NETWORK, OP_FLAG_GENERATOR and a combination of & and | those two together. The permission issue doesn't go away.
Is creating a subnet-like ROP node possible? I feel like I'm missing a subtle piece of implemenation.
I've attached an image of the error I get.
Thanks for the help.
