surfsec
   Views 1756   Replies 3   Subscribers 0
I made a test file for a problem with surfsec and i get some errors.
when i cut out some parts i get sometimes no cut at all.
(can be tested when in the curve sop the points get moved)
or i get some error cut's.
My question: is there a better way to work with nurbs? or how it can get solved?
surfsec_problem_H14_467.hipnc (84.6 KB)
looks like surfsec doesn't get much used… when i find a solution how to solve the problem i will update it here.
I usually fix these by playing with Tolerance. I mange to fix your scene like that too. On surfsect node it looks that artefact surface is there but on Convert node it is gone.
Modeled this with surfsect http://www.evernote.com/shard/s234/sh/ca45778b-6e24-449b-9e5e-a3a3b7038670/7c788f95c6b83569282d94685d5d757b [evernote.com] (exclude handle part)
Viewport
http://www.evernote.com/shard/s234/sh/643e4539-cd71-4c66-a456-e48acb115672/b1b1e1677e8a25e527de2d719f5adf88 [evernote.com]
Thank you for the information. thank you :-)
