Hello, I saw some older tutorial about How to import tracking data into Houdini 10 https://vimeo.com/17870587, [vimeo.com] run created PFTrack script, all is imported ok. But I can't get to see a background movie for my camera even if I have under viewport options enabled bg inages and also loaded bg movie in camera node under view tab. On Camera node > Edit parameters - there is no option to add a View Roto.
How are you doing to see backgroung camera movie in viewport and render?
Thanks for an answer…
PFTrack to Houdini 14 - View Roto is missing
4195 5 1- Teress
- 23 posts
- malexander
- スタッフ
- 5218 posts
- Teress
- 23 posts
- cudarsjanis
- 11 posts
- bonsak
- 459 posts
Hi
File sequences works fine here but quicktime doesn't.
Make sure you use “$F4” instead of the actual frame number when you load file sequences. If you tick “Show file sequence as one entry” in the file dialog before you click on the file, this will happen automatically.
-b
PS:
Just a friendly tip: If nobody answers a post here, ( which is not unusual ) it's probably because people are too busy or don't know or don't want to or some other perfectly legit reason.
Read the manual, search the net, use your imagination and figure it out yourself so you can help the next guy, or go and have a couple of beers. I don't know. If you want direct answers, Sesi support is your best bet. They are very responsive and very helpful.
In my opinion this forum is on of the best software forums i have ever used. Frequented by beginners in one end and super advanced professionals in the other. Everybody try to help the best they can and the tone is usually very polite and friendly.
Well, enough of me “mini ranting” Hope you figure it out.
-b
PS:
- cudarsjanis
- 11 posts
Thanks for the reply.
My mistake was quite stupid. My IMG sequence wasn`t starting on frame one, because of the time code on footage. Exported the sequence with proper time code. and starting from a frame 001. and everything worked perfectly
bonsak
Hi
-b
PS:
